Image Resizer Errors
Thread began 3/01/2016 10:14 am by tmcbinc99963 | Last modified 3/02/2016 1:00 pm by Ray Borduin | 1349 views | 6 replies |
tmcbinc99963
I added the WA Image Resizer to my Product Results table. It works in Live view but I get 'cached resize' errors when viewing off the server. The Private Message area wasn't available for this post, so I substituted 'WebsiteLink' in URL. The URL is in my DataAssist Search Pages Private Message posts.
Warning: require_once(webassist/caching/CachedResize_Image.php) [function.require-once]: failed to open stream: No such file or directory in /services/webpages/util/p/j/pjeq5yzb.attwebspace.com/WebsiteLink/Prod_results.php on line 9
Fatal error: require_once() [function.require]: Failed opening required 'webassist/caching/CachedResize_Image.php' (include_path='.') in /services/webpages/util/p/j/pjeq5yzb.attwebspace.com/WebsiteLink/Prod_results.php on line 9
This error implies that you haven't uploaded the file: webassist/caching/CachedResize_Image.php to the remote server. Make sure you have uploaded that file and this error should go away.
tmcbinc99963
The error went away, but now I get the question mark icon on all the images.
It could be a permissions problem with the cache folder. I'd need to debug directly to know for sure. Do you have a url where I can see the problem and can you give me ftp access to debug it? That will allow me to look into it further.
tmcbinc99963
URL and FTP credentials in Private Message
You have the folder referenced as "images/products" but the folder was named "images/Products" on the live server. I updated the folder name on the page and they display now.
tmcbinc99963
That fixed the issue. Thanks.
