adding multiple lines
Hey Ray
How would you go about creating an insert page which allows you to add multiple lines (eg an invoice where you can add multiple items) on the same insert - is this possible without something like ajax?
Jamie
Hey Ray
Jamie
It is possible, but how it is done depends on the user experience you want to support.
One solution might be to use eCart. You could use "add to cart" buttons as "add to invoice" and then save them all to the database with store cart summary and store cart details in database when you are done.
cool thanks, will have a play with trying it out using ecart
cheers Ray
