User Login Blocked
Thread began 2/29/2016 1:47 pm by Kumel | Last modified 3/01/2016 12:02 am by Ray Borduin | 593 views | 11 replies |
Kumel
User Login Blocked
After creating Login pages & etc with security assist, I added new column on users table as Deleted.
So if a user is deleted then Y else N.
Default value for column: Deleted is 'N'
So lets say if a user is Deleted. So his data is not deleted but then just column Deleted becomes 'Y' (Yes)
So lets say if that same deleted user tries to login, How do we not let him login & also display error at login page as to he was deleted so he can not login.
How do we do this?
You can store the value of the Deleted column in the session, then update the Security Assist Rule so that the value of the session variable has to equal "N" in order to pass the validation.
Kumel
so i went into login.php
from server behavior panel i clicked SecurityAssist Authenticate user it contained this at start:
if((((isset($_SESSION["SecurityAssist_ID"]) && $_SESSION["SecurityAssist_ID"] != "")?"LoggedIn":"") == "")&&(((isset($_COOKIE["AutoLoginUN"]))?$_COOKIE["AutoLoginUN"]:"") != "")&&(((isset($_COOKIE["AutoLoginPWD"]))?$_COOKIE["AutoLoginPWD"]:"") != "")){
After clicking,under session values i choosed Deleted and did ok.
update how?
There are two authenticate server behaviors on the page. Make sure you update both of them to store the Deleted column in the session.
Then go to the security assist rule and add "Restrict IF" $_SESSION['Deleted'] = "Y" to the logged in user rule you are using to restrict access on the pages.
Kumel
I went to acces page rule, selected Logged in to Users. then screenshot attached.. i logged in using deleted user still it does login.
Kumel
Well seems like moving Deleted to top helped.
So how do we show error on homepage if user is blocked?
You could add a new Rule for "User Blocked" that is defined as "Allow Access" if $_SESSION['Deleted'] = "Y" and use that rule to conditionally show a message on the page.
Kumel
I added this into login page:
<?php if(WA_Auth_RulePasses("User Blocked")){ // Begin Show Region ?>
<div class="alert alert-danger alert-dismissible" role="alert">
<button type="button" class="close" data-dismiss="alert" aria-label="Close">
<span aria-hidden="true">×</span>
</button>
<p>User ID Block.<br>
Please contact your admin</p>
</div>
<?php } // End Show Region ?>
SecurityAssist rule file attached.
Doesn't display error if user deleted and tried to login..
login page also attached
The session variable name you used on your login page is: "UserDeleted" but in your rule you are referring to it as just "Deleted"... you need to make sure you are referencing the variable you are storing.
Kumel
Yes i checked on that. i made it UserDeleted. Still error is not displaying on login page.
Generally links becomes like this when username or password is wrong : login.php?invalid=true
but this case its : .../login.php?accesscheck=%2Floto%2Flatest%2Fdashboard.php%3F
