Date not visible in email
Can you have a look at the page below - it has an email trigger which is pulling through the name from a recordset but not the date...
I checked your database and there are no values for LoginDate in the table. I think the email is fine, it is your logic for saving the loginDate that isn't working since they are are all blank.
Weird - I just added the LoginUsername field to check if it was pulling through anything from that table, and it seems OK now.
