I'm getting a Syntax Error when I use the delete icon for a record on the results form I generated.
Thread began 2/17/2016 1:07 pm by anonymous | Last modified 2/18/2016 6:33 pm by Ray Borduin | 2061 views | 11 replies |
anonymous
I've generated forms using the form generation wizard and after everything was generated, I added some extra sorting parameters for the results page. When I use the delete button I now get the following...You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '%test%) ORDER BY Lastname, Firstname, Company, Zip, Phone, Email ASC LIMIT 0, 2' at line 1
How can I correct this? I've included the forms I've created and I've also tested this with the original forms I generated and I got the same error.
SUBSCRIP_detail-5.php
SUBSCRIP_insert-5.php
SUBSCRIP_results-4.php
SUBSCRIP_search-13.php
after line 153 add this:
echo($query_WADASUBSCRIP);
It appears to have something to do with the search on the page, but I'll need to see the full query to look into it further. I could need FTP access for this one to debug and edit files where necessary.
anonymous
Still the same result
Hello Ray... I tried inserting that line of code after line 153 on my results page but the same thing happened. I got the same error message and the record was not deleted. I've given you the log in to my page in the private section below.
Also... there was a search field I initially left out of my search page when I created it that I would like to add. The field is Addrprob. I've tried copying the code from another similar record and then adding in the right field... and I have the field included on the results form... but when I click "Search" the search form is not sending the field parameter to the results form. Could you please let me know what I've overlooked? This field is actually a "T" or "F" character that tells me whether the subscriber is online only or print so it's something I really need to include.
I'll provide me FTP log in in the private section of this message
Thanks in advance! Dan Lewis
SUBSCRIP_detail.php
SUBSCRIP_results.php
SUBSCRIP_search.php
SUBSCRIP_update.php
What are the exact steps to reproduce the problem. I went to that page, clicked the search button, then clicked delete for the first record and it deleted without errors.
I'll need to reproduce the problem before I can debug it.
Daniel
Deleting record
I did work on it a bit last night. Maybe I succeeded and didn't realize it. I'll try it with a different web browser too. That sometimes works
Do you have any pointers on how to add the searching capability for my search page. I did generate a new set of pages last night and experimented by using the new search page with the old results page and the search worked fine. So therefore I know the problem is with my search page not sending the information to the results page.
The delete worked fine from my alternate browser so maybe the problem is with Firefox. I'm glad that problem is solved.
I'm afraid I don't really understand the issue.
Please explain what doesn't work on your page. What steps to reproduce, the result, and what the expected result would be and I can try to help.
Daniel
Additional field on search page
Hello Ray... thanks for getting back to me. On my original search page at www.wheretheshowsare.com/subscribers-test I have a field to search called "Internet Only." The actual field in the database is "Addrprob" This is a field I have marked at "T" or "F" depending on whether the subscriber is an online only subscriber or not.
Originally when I generated the page I didn't include this as a search field... I added it yesterday. The problem is that when I enter a "T" or "F" into that field on the search page the submit button doesn't send that parameter to the results page. Obviously I missed some of the code necessary to make this happen. I did generate a new search page and I included that parameter and it works fine. But I would rather just add the search parameter to the existing page so I don't have to create the current search page from scratch.
I wondered it you could tell me what additional code I need to include so that the search will work.
Thank you! Dan Lewis
Can I get a current copy of the search and results page where you have tried?
Daniel
Search & results pages
Here you go.
SUBSCRIP_search.php
You have two fields in your form named Addrprob... you need to remove one or the other from the search page.
