Dynamic menus not showing on IE
Thread began 9/02/2009 10:57 am by info236657 | Last modified 9/14/2009 12:53 pm by Jason Byrnes | 3756 views | 6 replies |
info236657
Hi
I have develop a new menu using an MySQL database do render the menus. In FireFox is ok, but when I use IE (6 or 8) the dynamic menus are not visible.
You can test on teste.php
In IE you can see just the "Home Page" menu because that is not dynamic (if I create a static menu it work fine).
I try with safari and in my Mac it works but on PC it doesn't work like in IE.
Thank you if any one can help me.
I have tried your menu at:
teste.php
In IE 6, IE7, IE8, FireFox 3.5 and Safari 4.0. In all browsers the menu is rendering correctly. I am not able to reproduce the problem.
Joe.frazier380415
Similar Problem CSS Menus rendering as Links in IE 6 and IE 8
CSS Menus do not render correctly in IE. It renders properly in Safari:
index.html
If IE5 is in the Javascript code should exceptions be used for other versions of IE. Please help. Thanks.
Joe.frazier380415
Updating DTD fixed the IE problem
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
May need to be a new thread. However, in Opera the
<%@LANGUAGE="JAVASCRIPT" CODEPAGE="65001"%>
shows up, or renders directly.
What should I do so this text doesn't show up.
Since your page is an html page, the ASP code:
should be removed.
Raul
problem solved
Problem solved.Thanks.
You're welcome.
