Notice: Undefined variable: ATC_itemQuantity in
I get this message i can not fix it.
http://www.lafecorunesa.com/productos.php
It looks like you are trying to add to cart from the recordset, but the recordset code is below the add to cart code. The solution is probably to move the add to cart code lower on the page.
Try moving the code on lines:16-52 down below the recordset code that ends on line 161.
It looks like you are using a database connection named "shop" and your eCart is also named "shop"... that is causing conflicts.
You will have to rename one or the other.
I'd also move the code from lines: 11-18 down below the add to cart code that ends on line 183
