"MySQL 5.3"
My hosting provider is using MySQL 5.3 now, and wouldn't you know it, your PowerCMS Builder does not work with MySQL 5.3, just 5.2. Is there any way you can fix the problem I am having...
20151125T182623: www.thedeckedoutdonut.com/_mmServerScripts/MMHTTPDB.php
PHP Warning: mysql_connect(): Access denied for user 'powercms'@'10.1.112.116' (using password: YES) in /hermes/waloraweb001/b1280/as.deckedoutdonut/_mmServerScripts/mysql.php on line 533
20151125T182639: www.thedeckedoutdonut.com/_mmServerScripts/MMHTTPDB.php
20151125T182640: www.thedeckedoutdonut.com/_mmServerScripts/MMHTTPDB.php
20151125T182651: www.thedeckedoutdonut.com/_mmServerScripts/MMHTTPDB.php
20151125T184001: thedeckedoutdonut.com/install_cms/complete.php
PHP Warning: require_once(../images/installed.jpg): failed to open stream: No such file or directory in /hermes/waloraweb001/b1280/as.deckedoutdonut/WA_Globals/WA_Globals.php on line 59
PHP Fatal error: require_once(): Failed opening required '../images/installed.jpg' (include_path='.:/usr/local/lib/php-5.5.22-amd64/lib/php') in /hermes/waloraweb001/b1280/as.deckedoutdonut/WA_Globals/WA_Globals.php on line 59
20151125T184008: thedeckedoutdonut.com/admin_cms/index.php
20151125T184751: thedeckedoutdonut.com/admin_cms/index.php
20151125T184907: thedeckedoutdonut.com/admin_cms/index.php
20151125T191006: thedeckedoutdonut.com/admin_cms/index.php
PHP Fatal error: require_once(): Failed opening required '../images/installed.jpg' (include_path='.:/usr/local/lib/php-5.3.29-amd64/lib/php') in /hermes/waloraweb001/b1280/as.deckedoutdonut/WA_Globals/WA_Globals.php on line 59
20151125T191102: thedeckedoutdonut.com/admin_cms/index.php
