Errors when sending emails
Thread began 11/24/2015 11:33 am by Mags | Last modified 11/25/2015 10:35 am by Ray Borduin | 775 views | 4 replies |
Mags
I have some email pages set up so that my client can send emails through the website. This seems to work OK most of the time, however they've started getting error messages on some pages. I duplicated the pages in question and narrowed the recordset down to just a few email addresses and it worked fine with no errors, so I can only think that it's something to do with higher volumes of email - although there are only 561 records in total. Errors as follows:
Notice: Undefined variable: mailContent in /var/www/vhosts/[mywebsiteURL]/httpdocs/webassist/email/mail_php.php on line 113
This line repeats numerous times, ending with:
Warning: Cannot modify header information - headers already sent by (output started at /var/www/vhosts/[mywebsiteURL]/httpdocs/webassist/email/mail_php.php:113) in /var/www/vhosts/[mywebsiteURL]/httpdocs/jfb/email_all.php on line 137
On a separate page, the client is getting an internal server error after hitting Send. I added error reporting to the page but they don't even get to see the page, just the internal server error message.
In both the above instances, the emails appear to be getting sent successfully (I'm on the mailing list and receive them OK). Both pages are set to display a success message using page.php?sent=true after sending. I also set up email logging on both these pages but the emails aren't being logged in the database so no way of actually checking if they all went!
Can you attach a copy of the page: /webassist/email/mail_php.php
I'll take a look and see if I can spot what might cause this error.
Mags
Thanks Ray, here it is.
It appears that file has been hand edited for some reason and the altered code is causing the errors.
I've attached my clean version to this thread. Please try uploading it and see if the problem is corrected.
mail_php.php
Mags
Thanks Ray, I checked what the manual changes were and it's nothing I would have done - might have been Jason previously as he's made changes to a few files to fix past issues. Anyway I've uploaded the replacement file and everything appears to be working OK, although I won't really know for sure until the client does the next big mailing. Thanks again!
