SQL Query to fill a field with a number based on another field
Thread began 11/24/2015 10:53 am by Paul | Last modified 11/24/2015 3:10 pm by Ray Borduin | 1027 views | 4 replies |
Paul
I have a "SortOrder" field that I need to populate with a number (1, 2, 3, etc), based on the name in a ProductBrand field. I would like to expedite it by writing a sql query and could use some help.
So: If "ProductBrand" is XXXX, "SortOrder" is "1".
Is this for an insert or update statement? or are you just trying to display it from a SELECT statement? Is SortOrder an actual column in the table you are storing, or is it just a calculated value you want to be able to display and use on the page? I need a bit more context about how you are using the value and in what scenario.
Paul
Thanks, Ray.
No, it is not an update statement, I think. The client wants their products sorted by a specific ProductBrand first and then by price in descending order. So I figured to create a field called SortOrder and all of a specific brand would be #1 and so on. It just looked easier to run a query to enter "1" based on the productbrand field then manually enter it in phpmyadmin.
Does that help?
You don't need to add a column at all.
SELECT * from Products ORDER BY (ProductBrand = 'show first') DESC, ProductPrice DESC
Paul
Ahhh...the "show first" would be the specific brand they want to ALWAYS be first on the results page.
Perfect, Ray.
Thanks!
