Java error updating checkout.php
Thread began 11/19/2015 10:24 am by mrobben375515 | Last modified 11/19/2015 5:47 pm by Ray Borduin | 289 views | 3 replies |
mrobben375515
I am working with the base code from PowerStore 3. I have been updating the server behaviors when they are flagged as red to make sure the pages are updated with the new code. There were a number of flags on the checkout.php page that I corrected. However, there is 1 server behavior that is not updating. It is titled "SecurityAssist Show Region (Not No Payment Gateway). When I try to update it, I get the error "While executing onLoad in installer_onOpen.htm, the following JavaScript error(s) occurred: In the file "installer_onOpen": installAll is not defined.
I did delete the cache with correct some other problems I have had, but I am still getting this one. The URL is www.cutestpetcontest.com Can you help me correct this error please?
This sounds like an issue with the installation. Please post back with a US phone number or Skype contact information and I'll do a screen sharing session with you to figure out what is going on...
You may just need to delete the filecache .dat file from your users configuration folder.... that is the first thing I would try.
mrobben375515
I did delete the cache and still have the same issue. See PM for Skye and contact information.
We looked into this in a connect meeting... the show if code had been hand edited so that the close of the IF statement couldn't be found by the server behavior and therefor couldn't be updated... we were able to update the code so that it could be found properly and the error went away.
