paragraph tags added instead BR
Thread began 11/18/2015 2:44 am by russell298997 | Last modified 2/22/2016 10:06 am by Ray Borduin | 2691 views | 7 replies |
russell298997
Ive read all the threads here and am still getting the same problem and client is going mad!
I've tried changing every instance of
$CKEditor_config = array();
with
$CKEditor_config = array();$CKEditor_config["EnterMode"] = "CKEDITOR.ENTER_BR";
and i looked in the config.js page but that had nothing in it. i tried adding a line that was recommended but still I get paragraph tags
example page attached is tbl_copy_update.php
please help!!!
cheers
stylesheets.zip
Update the file:
/webassist/ckeditor/config.js
add this line into the the ediorConfig function you will find there:
config.enterMode = CKEDITOR.ENTER_BR;
you can add it at line 10
russell298997
tried this
updated the config.js file to:
* @license Copyright (c) 2003-2014, CKSource - Frederico Knabben. All rights reserved.
* For licensing, see LICENSE.html or http://ckeditor.com/license
CKEDITOR.editorConfig = function( config ) {
// Define changes to default configuration here. For example:
// config.language = 'fr';
// config.uiColor = '#AADC6E';
config.entermode = CKEDITOR.ENTER_BR};
is that correct - cos nothing appears to change with the CMS pages...?
Hmmm. Not sure why that doesn't work, but instead you can add it to the htmleditor php code on the page itself.
$CKEditor_config["enterMode"] = 2;
you will see other lines that start with:
$CKEditor_config
just add it into the mix with the others and it should take effect.
russell298997
Another ckeditor quirk
Also having problems that i dont want the input text wrapped in a <p> tag but it defaults to doing so. is there a way to tell it not to?
I don't think it does that in the most recent version... Try downloading and installing the latest version of DataBridge from our site. Then delete the webassist/ckeditor folder so that it gets recreated by adding an htmleditor field to a blank page and upload the newest code.
John
I have about five htmleditors on a page. Can I set one of them only to use paragraph tags? I assume I would have to do that in the PHP on the page. I see from above that $CKEditor_config["enterMode"] = 2; is for <br>. What is it for <p>? 1?
Thanks.
Yes. I believe that is correct.
