Hi, i can get the Free Tools Working on Win DW CS6
Thread began 11/18/2015 12:27 am by Laurent | Last modified 11/19/2015 11:23 am by Ray Borduin | 605 views | 3 replies |
Laurent
Hi, i can NOT get the Free Tools Working on Win DW CS6
I followed exactly the instructions on http://www.webassist.com/community/tutorials/view_tutorial.php?tid=95.
"For Windows Users Close Dreamweaver. Open a Windows Explorer window. In the Address bar enter %appdata% and click Enter. Open the Adobe directory. Open the Dreamweaver folder for the version of Dreamweaver you are using. Dreamweaver CS4 users only - open the en_US directory. Open the Configuration directory. Locate the WinFileCache.dat file. There may be some other numbers appended to this filename. Press Delete to delete this file. Open Dreamweaver. If the problem persists, you may need to uninstall your extensions, reinstall them, then delete the WinFileCache.dat file and open Dreamweaver."
Tried dozens times... Loggued into windows ADMIN account, same issue. Tried direct MXP link and also open the CS6 extension manager, click the install link and browse to the MXP File instead... Does not help.
I could see this in the DW JavaScript.log, maybe it can help ? :
"JS Error:
MM.WA_CanRun is not a function
filename:
lineno: 0
Lors de l'exécution de DWMenu_Insert_GoogleToolkit_search command dans menus.xml, la ou les erreurs JavaScript suivantes ont eu lieu :
TypeError: MM.WA_CanRun is not a function"
No one of the extensions of the Free Tools are working. Nothing happpens when clicking on them.
Noticed that in configuration\Floaters, if have 2 empty files WA_Installer.html and WA_Installer2.html
I am running DW CS6 on Windows7
Thank for helping
Regards
Laurent
The installer may not be running correctly due to accented characters in your username or elsewhere in your folder path.
We may need to use a screen sharing session to help you get it installed. Please post a US phone number or Skype contact information and I'll contact you to schedule a screen sharing session to help you resolve this issue.
Laurent
I've added you to my skype contacts... just message me there when you see we are both online and we can do a screen share to look into your issue.
