File Upload Error Cannot modify header information
Thread began 11/16/2015 2:32 am by acaciasd344844 | Last modified 11/17/2015 11:22 am by Ray Borduin | 2896 views | 2 replies |
acaciasd344844
Hi Guys
I am having a strange issue with the File Upload in data bridge. I have a page with the file upload behavior added then an insert record behavior. The idea is that the file is uploaded and the details then added to a database table. This table is then accessed via a record-set and displayed on the same page as acknowledgement. In side the insert record behaviour I have the page returning back to itself (After Insert) carrying a recordset variable. The page produces 2 errors
Warning: Cannot modify header information - headers already sent by (output started at C:\xampp\htdocs\vitalsat\pdf_upload_docs.php:316) in C:\xampp\htdocs\vitalsat\pdf_upload_docs.php on line 350
Warning: Cannot modify header information - headers already sent by (output started at C:\xampp\htdocs\vitalsat\pdf_upload_docs.php:316) in C:\xampp\htdocs\vitalsat\pdf_upload_docs.php on line 367
The file is uploaded but the recordset on the page does not display the new record in the list. Only when I refresh the page do I see the new record.
I have attached the file and an image for your attention.
It looks like your php code is too low on the page.
Move the code from lines 316-321 up to just below line 185.
Then move the code from lines 322-353 to just above the <!DOCTYPE line.
acaciasd344844
Thanks Ray that fixed it. Ahh
Well it fixed it working on my local host, but I am still getting warning errors when I upload the page to my online server. The upload is working and storing the details in the database and the page is being updated. As they are just warnings I will switch them off using error_reporting(0);
Thanks John
