Can't install v1.04
Thread began 11/13/2015 10:40 am by Ron | Last modified 11/13/2015 2:07 pm by Ray Borduin | 815 views | 2 replies |
Ron
Can't install v1.04
I had purchased MySQLi Server Behaviors v1.03. I returned it because it wasn't what I needed at the time. I have since rethought my needs and purchased v1.04. In the process of trying to install v1.04 there seems to be an issue. I can't dynamically connect to my DB because the OK button does nothing that the connection form and the WebAssist menu item only contains "Cookies" when I attempt to add WebAssist server behaviors.
I found the thread that listed this link: https://helpx.adobe.com/extension-manager/using/command-line.html#remove_an_extension_from_the_command_line
But this does not work. I think my issue is that I attempted to install v1.03 thinking I need it to do the upgrade to v1.04. From this I think I put something into a tailspin.
Thoughts?
Ron
Try using the DMXZone extension manager. It is much easier than going through the command line.
http://www.dmxzone.com/go/22670/dmxzone-extension-manager-for-dreamweaver/
Ron
Edited this entry as I was looking in the incorrect place.
