The datepicker doesnt work
The datepicker doesnt apper in the "fecha field" you can check if you visit: http://elmundodesepo.com/informacion-y-reservas.php
thanks
thanks
You are adding several other versions of jquery to the page at the bottom:
if (document.location.protocol != 'https:') document.write('\x3Cscript src="http://musecdn2.businesscatalyst.com/scripts/4.0/jquery-1.8.3.min.js" type="text/javascript">\x3C/script>');
</script>
window.jQuery || document.write('\x3Cscript src="scripts/jquery-1.8.3.min.js" type="text/javascript">\x3C/script>');
</script>
That is probably what is causing the conflicts. You may be able to remove those to fix the problem.
these code it is use by adobe muse...if remove the codo, the page doesnt work.
You may also be able to resolve it by changing the order of the code and moving the Jquery definition for the datepicker below these lines.
If you give me FTP access I'll debug it.
i moved below the lines, and remove this link: <script src="//ajax.googleapis.com/ajax/libs/jquery/1/jquery.min.js"></script> , it work, but i have trouble to save into the data base.
What is the trouble? Do you get an error? I'll need to see the latest version of the file.
