LDAP and SecurityAssist
I'm building an intranet for our client using SecurityAssist, however they have insisted that it has to validate users through their existing database because they have a single signon for all internal services. Having searched the forums already for this, I found a post from a while ago which said it wasn't possible to use SecurityAssist with LDAP, however their techies have set up a test version of the intranet and replaced some of the Webassist code with their own. Unfortunately, although this allows a user to login, they've removed the session variables from the Login page which means that I can't continue with the build because I was going to use those session variables to set up user access groups, show different content etc.
As a last resort, I wanted to show you the code they've put in place and see if you think there's any way it can run alongside the standard Webassist code? I've attached a zip file containing four files - an original and updated login page, and an original and updated sample page. Can you let me know if there's any way this can work? (I'm not holding my breath!)
