File Delete
Thread began 11/12/2015 9:45 am by Daniel | Last modified 11/18/2015 2:45 am by Ray Borduin | 434 views | 6 replies |
Daniel
File Delete
Hi have a for with five hidden fields that has bindings on them because I want to delete pictures.
Can you please tell me how to sort this error out so that it doesn't do this anymore:
Warning: unlink(C:\xampp\htdocs\testing_site\images): Permission denied in C:\xampp\htdocs\testing_site\webassist\file_manipulation\helperphp.php on line 779
It gives me this error with the first submit. If I press the submit a second time it deletes the files but I don't want to tell the client 'You have to press the button twice'.
Thank you very much.
This is a permissions problem saying that you don't have permissions to delete files from that folder. You can probably adjust the permissions of that folder through FTP.
Daniel
When is DataAssist going to be compatible with MySQLi?
We are still working on it and don't have a release date. I can add you to the beta team to test pre-release when that is available.
Daniel
Yes please I will be thankful for that.
I just want to hear from you: Dynamic dropdown is not coming out with new versions of Super Suite - Is 'Dynamic Drop Down', 'Create Dynamic Array' and 'Populate List From Array' also going to be compatible then?
Because I have: 'Dynamic Drop Down', 'Create Dynamic Array' and 'Populate List From Array'.
Yes all current functionality will be supported after the update using mySQLi
Daniel
Thank you very much
