Why is this page allowing access?
Thread began 11/12/2015 5:50 am by russell298997 | Last modified 11/12/2015 4:36 pm by Ray Borduin | 731 views | 3 replies |
russell298997
Have set up a log in page to admin back end pages, which is based on useremail and user password. that works fine. the "home" page for the users is teamhome.php. this page uses the session value TeamID, to populate the right club info.
i added a Restrict Access To Page behaviour and set up a rule called login2016. my rules were session value useremail = recordset value "email" and session value password = recordset field "password".
But if i try and access teampage.php without logging in it grants me access. it doesnt populate and club info as there is no session value, but i want it top refer me to the login page. what am i doing wrong?
have zipped what i guess are appropriate pages. thanks guys
webassist.zip
You can't refer to recordset values directly in security rules. They will be out of scope... also if both the Session variable and Recordset value don't exist, they will match and access will be granted.
The solution is probably to just verify the TeamID session variable exists as the rule.
russell298997
ok, i kinda get that. could you just confirm how i would write that rule, save me a bit of inevitable mucking around in the morning!!
thanks as ever Ray
Just use:
value: <?php echo($_SESSION['TeamID']); ?>
comparison: <>
compare to:
keep compare to blank and it will only allow access if the session variable TeamID has a value
