store values in login
Thread began 11/12/2015 6:07 am by Sarre | Last modified 11/13/2015 1:54 pm by Ray Borduin | 337 views | 3 replies |
Sarre
The Store Values option in Mysqli Server Behavior - Login is not working.
The column is not taking any data. If I write a name in "Save in session as:" - nothing is stored.
The fields are blank when I jump through them.
Make sure you have the latest version of the extension installed. If you still have issues I'll need to debug this with you in a screen sharing session... please post back with a US phone number or Skype contact information and I'll set up a meeting to investigate this with you directly.
Sarre
Thank you Ray,
Just checked that I have the latest version installed.
See PM
It works for me, so I'd have to debug it with you directly to figure out why it doesn't work for you.
You can manually add the stored values in the code:
$Authenticate->storeResult("ColumnName", "SessionName");
Just repeat that line for each variable you want stored after the addFilter() lines you have now.
