mysqli login. how to set logout to 24 hours
hi guys
how do i use the mysqli login function to keep the user logged in for 24 hours.
Its quite annoying as i find i get logged out after like 15 minutes and loose work
Matt
hi guys
Matt
You have to update the setting for session.gc_maxlifetime in the php.ini file. The setting is set in seconds.
