Blocked Resources???
This post has been deleted.
Can you provide the url of one of the pages that it says was affected? That shouldn't be a blocked resource, so I'll have to look into it further.
If you click on the blocked resource report it should show you why it was blocked and how to unblock it. That information would be helpful when looking into it.
It may not matter... this particular blocked resource should only be used when someone changes an option in the list. Since the google crawler shouldn't be doing that, the fact that it is blocked may be completely inconsequential and could be ignored since it won't affect google's ability to properly crawl the page.
Yes it looks like you have this in your robots.txt file:
Disallow: /*cart
Which prevents it from indexing anything with cart in the url, and the https://ginelectronics.com/webassist/plugins/shopping_cart/change_option.js file has cart in the url.
You can ignore it.. it won't effect the indexing of the page, or you can update the robots.txt file to use:
Disallow: /cart
That should prevent the cart page from being indexed, but still allow files in the /shopping_cart folder like the .js file to load.
