Unable Install eCart 6 using cmd
Thread began 11/04/2015 4:31 pm by Hunter | Last modified 11/05/2015 11:03 pm by Ray Borduin | 2114 views | 4 replies |
Hunter
http://blogs.adobe.com/dreamweaver/2015/08/installing-extensions-for-dreamweaver-cc-2015.html
Using the above link, I have been able to install webassist's data assist extension, but in my attempts to install eCart 6 I continuously get an error in the command prompt saying
C:\Exmancmd_Win>ExManCmd.exe /install.zxp
Failed to install, status = -160!
I am tired of this installation method installing eCart 6.
Please tell me what I should do. Since the other applications installed perfectly fine, I assume that the version of eCart is corrupt in some way.
I'd try using the DMXZone extension manager: http://www.dmxzone.com/go/22670/dmxzone-extension-manager-for-dreamweaver/
It is free and allows you to avoid the command line for installation.
Hunter
Thank you for your quick response Ray, but I've already tried using the DMXZone extension manager shortly after posting this in the fourms.
When I open Dreamweaver after DMXZone installs the extension, the program gets stuck trying to open the eCart tab and an error message pops up which reads:
The following JavaScript error(s) occured:
Unable to open script file "C:\Program Files\Adobe\Adobe
Dreamweaver CC
2015\Configuration\Shared\WebAssist\eCart\WA_RunCommand.js"
(error 3).
Any ideas on how to troubleshoot a JavaScript error specifically related to eCart?
Did the secondary installer run? You have to open a page in Dreamweaver and our secondary installer should run and add a few more files including the one mentioned in the error.
If it doesn't run or you still have that error, post a US phone number or Skype contact information and I'll debug it with you in a screen sharing session and get it working.
Hunter
Opening the page was what made it activate the installer. I can't believe I missed that step. Worked great, thanks
