javascript error with show region utility
When opening a 'Show Region' utility behaviour I am getting an error. See the attached screen shot.
It doesn't seem to effect the function of the behaviour but it obviously isn't right.
Any ideas?
Any ideas?
It is an inspection issue. The negative effect is that it won't re-populate the UI when editing an existing region settings, but won't have an effect after application.
Thanks for reporting it. I'll get it fixed for the next update.
