Manual
Hi do you have a Manual more detailed of how use the dataassist?
Thanks best regards!
There are a million ways you can use it... what is it you are trying to do? We may or may not have a tutorial on the topic.
hi ray thanks for your support . i trying to do event schedule, i found some issues about i dont know how solve it with the data assist, like by example if i use a triple key in the DB to validate the event is unique (place,date, hour) how do it using the data assist (is possible?) another things i found trying to do the proyect is in a large forms i have troubles in the insertion in some point i get many error , i solve this issue cuting the form in two steps for the insertion ( one insertion and then an update) . i hope you can advice me with some tips.
thanks best regards!
There isn't going to be a tutorial specific to an event scheduling application. You may want to use a premier support ticket and we can help you through where you are getting stuck.
It terms of doing a complex validation of unique events, the solution is probably to create a recordset that checks the database with a WHERE clause that checks all of the conditions. Then validate whether that recordset returns a result or not. This is something we could help you set up in a premier ticket as well.
