Insert of MySQL record with IP Address type field fails.
Thread began 11/02/2015 9:29 am by Elaine | Last modified 11/03/2015 11:08 am by Ray Borduin | 552 views | 1 replies |
Elaine
I created an insert page using DataAssist. One of the fields is an IP Address. The insert into the database fails no matter how I enter the IP Address. Attached is the input field & validation call. It always fails when I press the Submit button.
IP_Insert.txt
URL validation won't work for IP addresses. It is looking for a domain name not a bunch of numbers. You can probably use a regular expression validation instead.
This site: http://www.regexlib.com can be a good resource for finding regular expressions that meet your needs for validation.
