Text Area
Thread began 11/02/2015 6:11 am by Daniel | Last modified 11/03/2015 11:05 am by Ray Borduin | 1313 views | 1 replies |
Daniel
Text Area
Hi:
So what it is that I want it to do is the following:
If the administrator starts writing in the certain text area I want another text area to open up so that they can put more details into the certain table. I want it to be something like when I log in as a user to Webassist' website. Do you understand what I want to do?
Thank you for your help.
Daniel
I think you can use the "conditional region" server behavior to only display that row when an administrator is logged in. Then use a second conditional region to use a hidden form element with the same name attribute instead when it isn't the administrator so that the value will be maintained.
(if you are using mysqli then you wouldn't need the hidden form element, you could just set the parameter to "WA_IGNORE" so that it will maintain the previous value when nothing is entered.)
