ecart6 webinar
Thread began 11/02/2015 2:46 am by Php | Last modified 11/20/2015 2:25 pm by Ray Borduin | 1137 views | 25 replies |
Php
ecart6 webinar
i have attached the files. Also when i do show region the information is hidden even though it should be shown when once logged in..
I don't see the problem by looking at the files.
I'll need to debug them directly if you want help. If you post FTP information for your site and specific steps including the username and password you are using and pages you are trying to access so I can reproduce the problem, then I can debug it and get back to you with information about why it might not be working correctly.
Php
Hi thanks for replying.. i think i have figured it out.. what i want is now how i detach a framework theme from the login because im using it as a plugin on the user template but when i want it use on
the admin the same header is being on used on admin which is being on the user template?
Update: im working locally not online at the moment sorry..
when i try detach my template from the login its still add the template i tryed deleting the theme from server behaviour its doesnt seem to be doing anything?
I'll need to debug the live pages to figure out what is going on. Do you have a live server you can use? Maybe sign up for one with 1and1.com they only cost a couple of dollars per month and would allow me to help you debug issues as they arise since we could work on the same files.
Php
pm
That error means you haven't uploaded the webassist folder and all of its contents yet. Upload it and the error should go away.
Php
pm
I'm not sure what the current problem is or what I should be looking at... What error are you seeing? What page is the error on?
Php
This post has been deleted.
Php
Pm
