Form causing display edditing problem in Dreamweaver
Thread began 10/30/2015 7:44 am by Kamen Nikolov | Last modified 11/03/2015 3:01 am by Ray Borduin | 942 views | 3 replies |
Kamen Nikolov
Hello,
A year ago I have build a site and used The Form Builder to do that. this for for some reason is causing display edditing problem in Dreamweaver. It is almost impossible to edit the site in design view. I have to disable the the form if I have to work in design view. If I work in code view it is OK but I need to be able to do that in design view as well.
On the site (live) the form has no problem at all, only if I have edit in Dreamweaver.
Any suggestions?
Thank you.
Kamen
Please attach a copy of the page and associated .css files and I'll open it in Dreamweaver and see what I can figure out.
Kamen Nikolov
See below
Dreamweaver seems to not like the .css file you are using: _css/csd_style.css
Specifically it is choking on the style defined on line 15 where you update most tags to use position:relative.... for some reason that causes the Dreamweaver display to choke.
If you remove line 15 from that .css file it seems to correct the problem. I'm not sure why this is, it is something you could report to the Adobe Support team, but it isn't a file or style associated with a webassist product.
