Tax doesn't take into account voucher code amount
Thread began 10/30/2015 7:07 am by rob75685 | Last modified 11/03/2015 6:18 am by Ray Borduin | 352 views | 2 replies |
rob75685
hi there
I have successfully applied a voucher code to my eCart, and the correct discount comes up in the cart. However the tax which is set to 20% is still applied to the Sub-total without taking into consideration the discount.
For example:
One item added to the cart costing £135
Sub-total = £135
Discount code (set to 5%) = -£6.75
Tax = £27 (still 20% of Sub-total)
Can I get the taxable amount to be (Sub-total minus the discount) please ?
thanks very much for your help
Edit your tax rule in the cart object to base the tax on the "taxable total" instead of "the subtotal"... (they are both options in the dropdown)
If you attached a copy of the WA_eCart1.php file, that is the one I'd actually have to look at to give a line number reference of how to update it in the code directly.
rob75685
This post has been deleted.
