error your SQL syntax message after adding a checkbox on the Update form
mySQLi Update function works fine until I add include the checkbox on the form called "Primary", which is supposed to update the "Primary" column in the table (int / 1) to a "1" from the default 0. Field type in the Update function is qualified as a checkbox(1,0) "c" .. Insert function works just fine. Any suggestions are appreciated.
