I made a form and it is not working please help
Thread began 10/22/2015 5:21 pm by Webbie | Last modified 10/23/2015 1:48 pm by Ray Borduin | 639 views | 3 replies |
Webbie
I have two contact forms on my website, i hired a guy to optimize my site so its google friendly but now my forms are not active. all the CSS and PHP seems to be in tact but it is not active right now.
Can you take a look at my form code and tell me how i can fix this?
here is the web page i am referring too. http://ativoitrecycling.com/E-Waste-Pick-Up-Contact.php
There are a bunch of repeated .js files on the page stepping on each other and causing issues. I see you have three instances where you add the jquery core js file and two instances of jquery UI. All but the first should be removed, but I'd replace the first one with a googleapis.com reference instead of a local version.
Then at the bottom of the page you have repeated validation code five times. I'd delete all but the last one there.
Webbie
Thanks Ray,
I got the ones at the bottum those where easy to spot, however i didnt write this code i really have no idea what im looking at.
Assuming your a code guy, im hoping i can attach pictures of the remainder of the code that i am not 100 percent sure of and you can point out what is the
-Jquery core js file
-what the code look like for googleapis.com reference?
Sorry man, i just don't want to cause more problems on this form for the future since i need this problem to go away, its important for my company.
Lastly i do not know if it does anything or not but i changed the name of the page recently, would that be a problem for the code?
These lines appear twice:
<script src="//ajax.googleapis.com/ajax/libs/jquery/1/jquery.min.js" defer></script>
<script src="//ajax.googleapis.com/ajax/libs/jqueryui/1/jquery-ui.min.js" defer></script>
Then this line is on the top:
<script src="leadpages-template/js/jquery-1.9.1.min.js" defer type="text/javascript"></script>
Delete the line at the top and delete one of the two sets of repeated references. Then move the other set to the top where the line you deleted once was.
If you want me to look at code, please attach a copy of the file and not screen shots, it is too hard to read that way.
