Filtering Product Results question
Thread began 10/22/2015 9:55 am by Charles | Last modified 10/26/2015 2:50 pm by Ray Borduin | 816 views | 6 replies |
Charles
With your help, I have a good working products_results.php page. I now have 2 sites with different skins using the same DB,. I need to filter the Categories displayed when you rollover the "Products' button on the top Nav to display only the Categories designated for each particular site. So I need to add a statement like 'FROM category WHERE Stone_Center = 1' to filter the displayed categories on the dropdown. I've tried but can't seem to get it. Your help would be appreciated. You can see the dev site at http://outofchaos.net/sstone/www/index.php Rollover 'Products' and only a few categories should display if we get this right. Products_results.php is attached.
I don't really understand. The link you gave doesn't work, so I can see it.
When do you want the categories filtered? on the results page or in the menu? How do you know to filter it or not? I don't know what dropdown you are referring to filtering. The page you provided doesn't seem to have a dropdown on it.
Charles
Sorry for the incorrect link - see PM.
You can add: "WHERE Stone_Center = 1'" to lin e98 of the results page before the "GROUP BY".
It looks like you have already updated the menu.php page to have: "WHERE Schofield_Stone=1" is that working?
Charles
The Where clause in menu.php is working now and now filters the dropdown of categories correctly.
When I insert the "WHERE Stone_Center = 1'" to lin e98 of the results page before the "GROUP BY in the products_results.php, I get this error message: "Column 'Stone_Center' in where clause is ambiguous" Maybe a syntax issue?
You must have a column named Stone_Center in both the products and categories table. It just wants to know which one you are referring to. Try using:
WHERE category.Stone_Center = 1'
Charles
Thank you! I did have Stone_Center in both the categories and products table and since the menu.php is filtering the Categories, I wanted the products_results.php to filter the Products displayed. So I used Where products.Stone_Center=1 and that did the trick.
