Dynamic Dropdown menu
Thread began 10/20/2015 4:15 am by Daniel | Last modified 10/27/2015 1:27 pm by Ray Borduin | 1030 views | 8 replies |
Daniel
Hi.
Hope you are doing well?
I’m busy building a website for an estate agency. I have attached 2 pictures so that you can have a look at what I am planning to do and have done so far.
You will see that in the ‘FinnishedPage.jpg’ picture is the search functionality of what I’m planning to do. It has 5 options:
1. Province – Dropdown with 9 provinces – Provinces stored in Database(dropdown comes from database – did it with ‘select list’).
2. City – Dropdown with Main City of each province except 1 Province that has 2 cities – Cities stored in database.
3. Area of City/Suburb – Only one of the cities has ‘Area of City/Suburb’ which is also stored in the database.
4. Price – Stored in database.
5. Property Type – Stored in database.
How the above is supposed to work is: When the visitor chooses a province from the ‘province’ dropdown menu – that province’s main city is supposed to appear in the ‘City’ dropdown menu. So there is one city called Pretoria – if that city is chosen certain ‘Area of City/Suburb’ of that one city is supposed to appear in the ‘Area of City/Suburb’ menu.
Because what is is that I want to do is once they have chosen on the search menu it must search the database for the Property that the client has put in.
I went through one of the Dynamic dropdown tutorials – So what I saw was that the Dynamic dropdown only has the Parent Child option. Is there another way for me that will be applicable to what I want to use?
Thank you for your assistance.
Daniel.
You would just have to apply Dynamic Dropdowns more than once to cascade the parent-child relationship across to the third or more dropdown.
Daniel
Okay thank you. I will try and then let you know
Daniel
Hi thank you for your advice I followed it and it worked. I've attached a picture here for you so that you can have a look. What I now need help with is how do I pass the answers to draw data from the database?
Thank you.
When you submit the form the values will be submitted to the action page specified in the form.
Then you can use that information to filter the database by using the DataAssist Search server behavior that comes with Data Bridge.
Daniel
What I did was:
I created the dynamic dropdowns and then I created a form but when I opened the 'DataAssist Search' it only gives me the ability to choose from one recordset and I have 5.
Can you please explain to me how to do this?
Thank you.
Daniel.
You are trying to draw data from 5 tables based on the 5 selections? In that case you don't need to use Database Search. Just when you create the recordsets you can use the Simple view and choose to filter the recordset column with a form value and type in the associated form element name from the previous page.
Daniel
There are 5 tables and each table has a Primary Key. Some of the tables has a foreign - Then with the selection that has been made I want to draw data from a single table. But I don't know how to get the values from the form to pass them to the recordset query in order for the data to display from the database table.
You use JOIN statements to join all of the tables into a single recordset. Then you can either use parameters in your recordset or DataAssist Search in order to filter the results.
Get the unfiltered results showing from a single recordset first, then add the filter.
