power gallery server upload not seeing files in folder
Thread began 10/19/2015 9:53 am by mrobben375515 | Last modified 10/19/2015 3:36 pm by Ray Borduin | 969 views | 4 replies |
mrobben375515
I am trying to import a folder full of files without doing a single upload at a time. I upload the folder to my site. I used the "server upload" tab to point to the fold that I want PG2 to import the files from. The browse sees the folder, but when I click on the actual folder with the files, I get the error message "Image Folder does not exist! Click here to start over". When I click on the browse button, the folder is listed with the correct number of jpg files inside it.
Can I get a URL to reproduce the problem and FTP access to debug it? I'll have to do some testing to figure out what is going on.
mrobben375515
sure. see pm
It is probably the & in the folder name causing issues. Can you try renaming the folder to not use special characters and see if you get a better result.
mrobben375515
yes, that fixed it. Thank you!
