cant add products - errors
trying to add products to store but now receiving error. tried 2 different browsers - same error
Update line 171 and replace: "clientFstatusCodeileName " with "statusCode"
Can I see your products_insert.php page? I'll have to look at the code to figure out the other issues.
It is really weird. It was working fine all along then suddenly not. I currently can update and modify any current product no problem, it just wont let me add a new ones.
looking at the products_insert page - maybe something to do with the additional item charge code you added for me?
I will try the code fix. Thanks!
yes, update line 213 to:
$WA_columnTypesStr = "',none,''|',none,''|none,none,NULL|none,none,NULL|none,none,NULL|none,none,NULL|none,none,NULL|',none,''|',none,''|',none,''|',none,''|',none,''|',none,NULL|',none,NULL|none,none,NULL|none,1,0|none,1,0|',none,''|none,none,NULL|none,1,0|',none,''|',none,''|',none,''";
That fixed it Ray!! thanks for you amazing support as always
