can i merge the cmstables
Thread began 10/15/2015 4:30 pm by software.current355386 | Last modified 10/15/2015 7:47 pm by Ray Borduin | 703 views | 1 replies |
i have test and live version of a cms database, i appear to have gout valid data split btween them.
if i delete entries not required, can i export tsbe and import givin 1 valid DB.
iF yes whih tabl to export and the sequence to import
The pcms2_contents table is probably the only one you need to worry about, but yes you should be able to merge them.
