Re-installation of Power CMS
Seems to be missing files can't login and credentials not showing up in WA Settings table. Do I need to clear certain files before attempting re-installation?
I think you just have to clear the installed.txt file from the connections folder and it should run the installer again. It depends on the version of PowerCMS you are using and whether you are trying to install from a browser or from within Dreamweaver.
