Databridge DatePicker and bootstrap
Is there a workaround for DatePicker for bootstrap pages?
when i add a form and that form has class form-control the data picker doesn't work
Can I see a sample page? I think it should work.
ok it worked so i think i had something to do with the frame template i was using but when i regenerated the files using a raw bootstrap page it worked
Thanks for reporting the issue. I'll try to reproduce it and see if we can get it fixed.
