Form not submitting
I have a form built with Webassist that is not submitting. I checked the usual suspects but am not seeing the issue. Can you help me?
I will attach the file
Is there a url where I can see the page live and demonstrate the problem? I'd like to start with that before looking at the code.
See PM
You have some script on the top of the page that has to be moved to the bottom.
If you take this code from the header:
<script src="webassist/forms/wa_servervalidation.js" type="text/javascript"></script>
<script src="webassist/forms/WA_ShowCVV.js" type="text/javascript"></script>
<script src="webassist/jq_validation/jquery.h5validate.js"></script>
<script>
var spacereservation_Mastergraphx_adspaceform_Opts = {
focusout: true,
focusin: false,
change: false,
keyup: false,
popupClass: "Bloom",
pointedAt: "left",
fieldOffset: 10,
fieldMargin: 2,
position: "left",
direction: "left",
border: 1,
offset: 25,
closeText: "✖",
percentWidth: 100,
orientation: "bottom"
function spacereservation_Mastergraphx_adspaceform_Validate() {
$("#spacereservation_Mastergraphx_adspaceform").h5Validate(spacereservation_Mastergraphx_adspaceform_Opts);
$(document).ready(function () {
ConvertServerErrors(spacereservation_Mastergraphx_adspaceform_Opts);
</script>
and move it to the bottom replacing this line which isn't necessary:
<script src="http://ajax.googleapis.com/ajax/libs/jquery/1.7.1/jquery.min.js"></script>
I think that will fix the problem.
Ray,
Thanks for you help. I recreate the form and it is now working.
