Log In User - password case-sensitive
How do I modify the code to make the password case-sensitive? I'm aware that using BINARY in a query will do the trick but I'm not sure how to apply this to the SB code.
Just update the collation for that column in the database itself to use a binary collation like: latin1_bin
Thanks Ray, did the trick.
