Out of memory
Thread began 10/01/2015 12:57 pm by john70964 | Last modified 10/02/2015 1:37 pm by Ray Borduin | 791 views | 2 replies |
john70964
Out of memory
Hello,
I am getting an error message when I try to upload an image in http://boatsforsalenow.com
Fatal error: Out of memory (allocated 61341696) (tried to allocate 17676 bytes) in /homepages/37/d415519235/htdocs/boatsforsalenow/webassist/file_manipulation/helperphp.php on line 891
The image size is 1MB which is about right.
Have you an idea where I should start looking for the problem.
I believe this has happened before but usually it has been working fine.
John
Are you resizing the image while uploading? The image resize process takes up a lot of memory. Usually the only solution is to up the available memory_limit value in the php.ini file. You can sometimes fix it on the top of the page with php on the top of the page as well like:
ini_set
('memory_limit''1024M');
That would be more than enough, but there may be limits or you may not be able to change it at all on a shared server.
john70964
Thanks Ray,
I will try to get the php.ini file uploaded on the remote server first.
Regards
John
