MySQLi automatically login user after registration
Thread began 9/25/2015 1:42 pm by eric284736 | Last modified 10/04/2015 7:25 pm by Ray Borduin | 1097 views | 4 replies |
eric284736
Hi
I have a MySQLi insert record that saves the id in a session named "memberreg" and I want it to automatically take them to the member area without having to login again.
Is that possible?
thx
Eric
You should be able to apply the authenticate user server behavior on the registration page and log the user in immediately after the registration. Just remove the redirect in the registration insert and make sure the authenticate user code is placed after the registration code.
eric284736
Hi Ray,
Are you saying use the Security Assist Authenticate User with the MySQLi Insert Record (that is how I am registering people)?
Thx
Eric
Whatever version you are using on your login page (assuming you have one) you can use on the registration page as well. If you don't already have a login page then you could use either the Security Assist version or the MySQLi version.
eric284736
Thanks Ray!
