Looping Update query
Thread began 9/24/2015 10:49 am by LionsMane | Last modified 9/24/2015 12:53 pm by Ray Borduin | 875 views | 3 replies |
LionsMane
I can use your mySQLi update behaviors to update two tables on one submittal, but the issue is that I may have multiple records in a table, and I want to update ALL of those qualified records. How do I set that update for ALL related records?
How do you define "Qualified Records"? I need more specifics. Are they all updated with the same value or do they have different values? Are you repeating a form? The specific details about what you want updated are important when determining how to do it.
LionsMane
Sorry, my bad for not giving enough details. Here's the scenario - There are two tables, Parent and Child. When I run the update I can have two updates, one that updates the Status column of the Parent table, and a second that updates the same Status column on a single record in the Child table, where the ParentID is also stored. But what happens when there are two children for that parent? I need to be able to update ALL children of that same parent.
In your update server behavior specify the lookup column the updated rows share, not necessarily the unique id of the table. It will update all rows that the lookup column matches the lookup value you enter.
