checkout_success.php
Hey Ray
How would you go about creating content for the page to test it and to view the styling?
Cheers
Jamie
Hey Ray
Cheers
Jamie
I'd probably just update the trigger for the transaction processing so that it didn't actually bill the card and then run through the checkout. Then manually browse to the checkout_success.php page after submitting the card information.
Open the confirm page and double click on the server behavior that does your credit card processing for whatever payment provider you are using. Then change the trigger to: ""
That should cause the transaction not to process, but the rest of the code would still run so that you could populate everything before browsing to the checkout success page manually to see how it would look.
cheers Ray
There seems to only be the paypal authentication when there should also be sagepay - http://prntscr.com/8j44c2
have also noticed that in the new iteration of the site that I mentioned in email, the coupon/discount value isnt being passed to paypal..
Please attach a copy of the page. Is it possible the sagepay code was hand edited so that it won't be recognized by Dreamweaver? I'll take a look.
Oh yeah... sagepay doesn't use a server behavior because it is all done with hidden form elements. That is why you won't see a server behavior for it.
You'll have to use a different technique in this case. Can you send me the success page? I'll take a look at it and find out what you can change to get it to open so you can work on the design without processing an order.
It might be easier to just create a $0.01 item and process an order to see the live result... but I'll show you how so you can decide which route you want to take.
You can just browse to the success page by typing in the url after filling out the checkout form without pressing the "process payment" button.
It looks like you need to update your padding on that button as well.... add this class to your css:
#Payment_Info .NewFromBlank_Default li {
margin: 0 40px;
