post to thank you page
Thread began 9/15/2015 7:18 am by BjB | Last modified 9/15/2015 10:56 am by Ray Borduin | 360 views | 2 replies |
BjB
I have a form with an Email Address field in it. When I submit the form it takes you to a thankyou.php page. On the thankyou.php page I'm trying to show the email address that was entered using the code below, but nothing shows up.
I have this code on the form page:
<?php $myemail = $_POST['Email_Address']; ?>
And this code on the thank you page:
<?php echo $myemail; ?>
What am I doing wrong?
The form posts to itself and then redirects to the thank you page, so you can't refer to the form post on the thank you page directly.
The solution is to save the email address into the session on the top of the email page so you can retrieve and display it from the session on the thank you page. You can use the webassist "Persist Form" to save the entire submitted form to the session and retrieve it that way, or just use the "Set Session Value" server behavior to set a single session variable from the email field.
BjB
Got it! Don't know why I didn't think of that.
