jquery ui
Thread began 9/15/2015 7:15 am by Jamie | Last modified 9/16/2015 11:55 pm by Ray Borduin | 606 views | 4 replies |
Jamie
jquery ui
Hey Ray
KJust wondering if you wouldnt mind taking a moment to look at an issue I am having.
Basically, I am trying to implement a set of tabbed panels using the jquery ui system (https://jqueryui.com/) but the tabs just arent working.
I have successfully got the same content to work as an accordion so to test that I was implementing it correctly.
So, the tabs (not working) are here: http://clients.motley.site/friths2/contact.php
and the accordion version (working) is here http://clients.motley.site/friths2/contact2.php
The tabs are also working on a simple static html version of the page: http://clients.motley.site/friths2/test-tabs/contact.html
Many thanks
Jamie
It looks like that page doesn't have the js:
<script>
$(function() {
$( "#tabs" ).tabs({
</script>
Jamie
hmm not sure why that happened...have re-added it and still getting the same although, and this is what has been happening all day, for some reason the home page is being populated between the tabs and the content....
The page seems to have some looping .js that keeps reloading the other .js files on the page. I'd try removing the other .js on the page to narrow down the conflict.
Jamie
thanks Ray. Have gone through it, stripped everything out and started from scratch and not able to pinpoint what is going on. spent far too much time trying to figure it out so have decided just to use the accordion effect. Just strange that Thanks for taking a look though, really appreciate all your help!
Jamie
