Bottom Nav overlaps Top Nav flyouts
Thread began 9/10/2015 12:20 pm by Charles | Last modified 9/14/2015 11:56 am by Ray Borduin | 438 views | 2 replies |
Charles
We have created a top nav and bottom nav using 2 different CSSmenuwriter files - attached. Look at the following URL and rollover 'Products' in the top nav. When the Categories flyout they underlap the bottom nav and the bottom selections become unusable: http://outofchaos.net/gsc/www/products_detail.php?ID=17
Is there a change we can make to either the top or bottom menu.php or css that will have the flyout overlap the bottomnav? Thanks for your help.
In the CSS for the second menu main UL (CSSMenuWriter/cssmw6/menu.css line 1) add:
position: relative;
Then in the CSS for the first menu sub-menus (CSSMenuWriter/cssmw3/menu.css line 43) add:
z-index: 9999;
That should fix it.
Charles
That worked! Thank you.
