LOGIN REDIRECT NOT WOKRING FOR SQL and SQLi
Thread began 8/26/2015 1:01 pm by jdjackson | Last modified 8/26/2015 7:40 pm by Ray Borduin | 1264 views | 5 replies |
jdjackson
LOGIN REDIRECT NOT WOKRING FOR SQL and SQLi USER AUTHENICATION
The redirect had been working but when I tried to create a new check user page, the attached page hangs and will not redirect. I then tried the SQLi version with same result. I think the problem may be in the helper_php and I have attached it
NEW TOPIC VIRTUAL()
I am having issues with virtual(). The production server will not accept it. I have to change to require(). Is there a way to configure DW not to default to virtual().
Thanks...John
Login66Nop2.zip
helper_php.zip
If you change your site settings to use "relative" instead of "absolute" links it will use require instead of include.
I don't see a problem with the page. Does it give an error? Does it log in, just not redirect?
jdjackson
NO ERROR MESSAGE
It gives no error message. It seems the login is authenticated, it just does not return from helper_php.
Does the sequence of the fields to be authenticated matter. Do UID and PWD have be in the first two fields?
The sequence would not matter. If you give me ftp access to the files I can debug and figure out why it isn't working properly.
jdjackson
WORKING WIHOUT EXPANATION - VIRTUAL()
I just tested the page on both the local and remote sever and now it is functioning properly. The problem has appeared and disappeared without explanation.
I still have to change virtual() to require_once(). Anyway to stop virtual() from being entered in DW?
Thanks for your help...John
Change your site definition in Dreamweaver and change it from using "absolute" links to "relative" links and it should use require instead of virtual.
