im following the ecart 6 webinar when i to about 18 min and i preview my page why at the top undefined variable?
Thread began 8/24/2015 5:14 pm by Php | Last modified 9/14/2015 5:35 pm by Ray Borduin | 740 views | 12 replies |
Php
im following the ecart 6 webinar when i reach to about 18 min and i preview my page everything working but why do i get at the top undefined variable?
my page is loading fine but why at the top i have undefined variable?? im following the ecart 6 webinar?
Please provide a copy of the products_results.php page that displays this error.
I think the issue is with using "display all records" and it not defining the pagination variables since all records are displayed. Since you are displaying all records, you can probably delete the pagination section of the results page that should include the line with the error.
Php
The page looks fine. If it happens again then post back here with FTP information in the private area and a URL where I can view the problem and I can debug it.
Php
ecart 6 webinar 120 setting up ecart not directing to cart.php
i managed to fix the other problem, now im having an issue where the products are setup when i go to my detail page and click on add to cart it should direct me to cart.php buts its not? im following the the ecart webinar im at 1 hour and 20min in im stuck here? im attaching the details page..
thanks you
Try changing the Add to Cart server behavior trigger to use the add to cart button press.
Php
products_detail.php
It looks like you have the quantity set to the recordset column: ProductMetaKeywords
You should probably just bind it to the number: 1 or add a quantity field to your form to bind it to.
Php
Do you have a URL where I can see the problem? It looks like it would work... the quantity field is now set to the field "ProductUnlimited"... which still seems wrong. You should just set it to: 1
